Revit Extension for Robot Reinforcement Design
12 REPLIES 12
Message 1 of 13
1010 Views, 12 Replies
Is it must for me to install the revit extension for design and transfer of reinforcements from Robot?
12 REPLIES 12
Message 2 of 13
Rafal.Gaweda
Yes.
Rafal Gaweda
Message 3 of 13
in reply to: Rafal.Gaweda
Hi Rafal,
What I do now is. I model in Revit , den transfer it to robot , apply loads, imposed constrains , analyse and finally design it (RCC).
After designing, is it must for me to design again if I have to import the reinforcement
Becuase when i perform Reinforcement Code Check, I am doing the entire analysis again inorder to enable the import reinforcement button.
Kindly correct my procedure if I am doing it the wrong way.
Reinforcement import is perfect btw
CVP
Message 4 of 13
Rafal.Gaweda
Example video:
Rafal Gaweda
Message 5 of 13
That was amazing. I was using reinforcement code check to import. Hats off man !!!
Message 6 of 13
Is there any wat i can save this video?
Message 7 of 13
Rafal.Gaweda
Install GetThemAll Video Downaloader addin for Chrome and use it while playing video to downalod
Rafal Gaweda
Message 8 of 13
Thanks Rafal. Kudos!!!
Message 9 of 13
Will this work in 2015 version too?
Message 10 of 13
Rafal.Gaweda
Yes.
Rafal Gaweda
Message 11 of 13
Hi Rafal,
When i tried updating, it is showing this warning.
I have applied loads, peformed the analysis and calculated the Column Reinforcements. The reinforcements were visible. But when i update in Revit, it is not showing.
Kindly help as im stuck with this for a long long time.
Message 12 of 13
Rafal.Gaweda
The marked warning is related to panels reinforcement.
Besides the warning - there is no reinforcement transfer between R and R for panels , walls, slabs reinforcement
Rafal Gaweda
Message 13 of 13
Hi Rafal,
Can you screencast the video on how to transfer/update in revit. Your previous video was very helpful but I am not able to bring it back to revit file.
And also i am not able to see the reinforcement after updating. Require your help.
