Wind load generation in frame generation add-in
Hello! it seems to me that the wind load doesn't work for the frame generator (Add-in) using the French Code (Eurocode). Although it works using the Wind and Snow load 2D/ 3D. I don't know why. Can someone help me with this issue?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you for notifying us about this situation. As far as I can see the values of loads are incorrectly generated as 1.#. We will investigate why this happens.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Corrected in SP4 for RSA 2016.
Artur Kosakowski
