(API) Why Robot didn't show the strain Resultant from Axial , bending ,and shear
mustafahesenow
Advisor Advisor
mustafahesenow
Hi all,
I just want to ask why robot is not calculating the strain  of bar and shell elements resultant from Axial  , bending , and shear  since its will be the most important to check the failure Direct and the criteria of stopping nonlinear analysis is only related to the stain calculation .
Regards.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Rafal.Gaweda
Autodesk Support
Autodesk Support
You can calculate it using API.
See attached example.
Rafal Gaweda
mustafahesenow
what about the panels ??
Mustafa Hesenow
LinkedIn
Rafal.Gaweda
Autodesk Support
Autodesk Support
More complex, but can be done ; from stresses I guess
Rafal Gaweda
mustafahesenow
yes It can for sure thats why I think that adding this features to robot as maps for panels and bars  will powerfull and helpfull alot  especially for checking the faluire of the sections which is robot already calculate it but didnt show it .
Mustafa Hesenow
LinkedIn
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal.Gaweda
Autodesk Support
Autodesk Support
Panel strains macro attached
Rafal Gaweda
