Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Revit Extension for Robot Reinforcement Design
12 REPLIES 12
Message 1 of 13
976 Views, 12 Replies
Is it must for me to install the revit extension for design and transfer of reinforcements from Robot?
12 REPLIES 12
Message 2 of 13
Rafal.Gaweda
Yes.
Rafal Gaweda
Message 3 of 13
in reply to: Rafal.Gaweda
Hi Rafal,
What I do now is. I model in Revit , den transfer it to robot , apply loads, imposed constrains , analyse and finally design it (RCC).
After designing, is it must for me to design again if I have to import the reinforcement
Becuase when i perform Reinforcement Code Check, I am doing the entire analysis again inorder to enable the import reinforcement button.
Kindly correct my procedure if I am doing it the wrong way.
Reinforcement import is perfect btw
CVP
Message 4 of 13
Rafal.Gaweda
Example video:
Rafal Gaweda
Message 5 of 13
That was amazing. I was using reinforcement code check to import. Hats off man !!!
Message 6 of 13
Is there any wat i can save this video?
Message 7 of 13
Rafal.Gaweda
Install GetThemAll Video Downaloader addin for Chrome and use it while playing video to downalod
Rafal Gaweda
Message 8 of 13
Thanks Rafal. Kudos!!!
Message 9 of 13
Will this work in 2015 version too?
Message 10 of 13
Rafal.Gaweda
Yes.
Rafal Gaweda
Message 11 of 13
Hi Rafal,
When i tried updating, it is showing this warning.
I have applied loads, peformed the analysis and calculated the Column Reinforcements. The reinforcements were visible. But when i update in Revit, it is not showing.
Kindly help as im stuck with this for a long long time.
Message 12 of 13
Rafal.Gaweda
The marked warning is related to panels reinforcement.
Besides the warning - there is no reinforcement transfer between R and R for panels , walls, slabs reinforcement
Rafal Gaweda
Message 13 of 13
Hi Rafal,
Can you screencast the video on how to transfer/update in revit. Your previous video was very helpful but I am not able to bring it back to revit file.
And also i am not able to see the reinforcement after updating. Require your help.
Technology Administrators
