I cannot get results connect to show in the excel. It is not even visible in the comm addins of excel.
I have installed it via the autodesk apps website but doesnt seem to work. Any help?
Solved by LeeCastro. Go to Solution.
If it's installed right it will be shown in the addins even if it's not activated in Excel.
Try to download it and reinstall it again here: https://apps.autodesk.com/RSA/en/Detail/Index?id=3823007601230525320&appLang=en&os=Win64
Then, what's your office version you are using??
In Microsoft Excel, Select “Options”, then “Add-ins”.
In "Inactive Application Add-ins" select "Results Connect".
In Manage select "COM Add-in”, then "Go”.
Select "Results Connect" then "OK".
my com add-ins doesnt have results connect. see below. That is my issue.
Try add and select the Results connect path as here in the pic:
If the Results Connect API is installed in your computer you will find it's system files here:
C:\Program Files\Autodesk\Results Connect\2016\Framework
for some reason it say it is not a valid add-in (see image)
This error is typically indicative of a corrupted Results Connect profile. To resolve the issue, re-create the profile by following these steps:
