Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Results connect
8 REPLIES 8
Message 1 of 9
1412 Views, 8 Replies
Results connect
I cannot get results connect to show in the excel. It is not even visible in the comm addins of excel.
I have installed it via the autodesk apps website but doesnt seem to work. Any help?
Results connect
8 REPLIES 8
Message 2 of 9
Muhammed.OPERA
Muhammed.OPERA
If it's installed right it will be shown in the addins even if it's not activated in Excel.
Try to download it and reinstall it again here: https://apps.autodesk.com/RSA/en/Detail/Index?id=3823007601230525320&appLang=en&os=Win64
Then, what's your office version you are using??
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Facebook |LinkedIn
Message 3 of 9
in reply to: Muhammed.OPERA
I am using office 365. I have installed it but still doesn't appear.
Message 4 of 9
can someone help with this please?
Message 5 of 9
Muhammed.OPERA
Muhammed.OPERA
In Microsoft Excel, Select “Options”, then “Add-ins”.
In "Inactive Application Add-ins" select "Results Connect".
In Manage select "COM Add-in”, then "Go”.
Select "Results Connect" then "OK".
Facebook |LinkedIn
Facebook |LinkedIn
Message 6 of 9
my com add-ins doesnt have results connect. see below. That is my issue.
Message 7 of 9
Muhammed.OPERA
Muhammed.OPERA
Try add and select the Results connect path as here in the pic:
If the Results Connect API is installed in your computer you will find it's system files here:
C:\Program Files\Autodesk\Results Connect\2016\Framework
Facebook |LinkedIn
Facebook |LinkedIn
Message 8 of 9
for some reason it say it is not a valid add-in (see image)
Message 9 of 9
LeeCastro
LeeCastro
This error is typically indicative of a corrupted Results Connect profile. To resolve the issue, re-create the profile by following these steps:
  1. Close any open instances of Excel.
  2. Open a Windows Explorer window and navigate to C:\Users\your-user-ID\AppData\Roaming\Autodesk
  3. Locate the folder titled Results Connect and rename it Results Connect_old.
  4. Restart Excel (the error should no longer occur)
Marque Aceitar como Solução e clique em Curtir.
Select Accept as Solution and click on Like
Li Chong Lee, DSc.
LinkedIn Instagram | Facebook | Twitter  | YouTube
Participante da Comunidade de Usuários Autodesk Brasil
Li Chong Lee, DSc.
