RC Element Design - Modul crushing
Message 1 of 11
I have RSA 2016 Professional with all service pack including SP4 installed.
Whne I am trying to run RC Element Design as new project or run it to design the foundation on existing steel or concrete structure it frezzes and I can't do anything.
Therefore I can't use this module at all which is preaty bad as I need to design large amount of foundations on one of the projects that I am working.
Can anybody help me with this isseue, please.
Thank you in advance.
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to empty Windows temp folder (%temp%) and rename your CfgUsr folder (to e.g. 1CfgUsr)
c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2016\CfgUsr\
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 11
Hi Artur,
Thank you for your response.
Unfortunettly it is still freezes and I need to restart the application.
Any other thoughts ?
Best Regards
Jan
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the model and indicate the steps to follow to reproduce this situation? Thank you.
Artur Kosakowski
Message 5 of 11
Hi Artur,
It happens with any model. When I am opening Robor and choose RC Element Design and for example choose to add pad foundation it crushes and I need to restart the program.
Best Regards
Jan
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Are you able to start e.g. a frame model?
Artur Kosakowski
Message 7 of 11
HI,
Yes I am working on shell model, structural framework models and they work absoluttly fine.
It is just the RC Element Module that behaves like this.
BR
Jan
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is there any crash report generated when you try to access RC modules?
Artur Kosakowski
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you check if it is the same when you set the acceleration to none and restart Robot?
Artur Kosakowski
Message 10 of 11
Hi Artur,
Unfortunnetly there is no report generated and switching of the accelaration as you suggest don't help.
I don't know 😞
BR
Jan
Message 11 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you tried to uninstall and install Robot again?
Artur Kosakowski
