Calculations freezes when regenerating meshes
Model does not calculate. The calculations stop at mesh regeneration stage. I have tried to open in repair mode, but it didn't help. Please find the file attached:
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check attached file and meshing options set.
Rafal Gaweda
Thanks, the model you attached works. Howerer, I have tried to correct the model I sent you according to your recommendations and it still freezes. I deleted all meshes and set the following parameters to all meshes:
What else was changed?
