Friction coefficient in foundation design
Hello
I’m designing a foundation under a steel column and have a question regarding sliding.
Calculations according to EN 1997-1 and EN 1992-1-1
In the soil parameters I can assign friction coefficient (ex 0,6). But in the calculation of sliding the given value isn’t used directly. Instead Robot uses:
Tan(δd)=0,3
What’s the relation between these coefficients? I can’t find anything in the help files.
See attached pdf.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
I had the smooth precast box ticked, which it shouldn’t be in this case. Now it adds up just right.
Thank you!
