steel connection - fixed column base
msoffietti
msoffietti
hello
I have a problem with the calculation of a fixed end connection.
Probably there is an error.
See the file PDF
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file with this connection?
Artur Kosakowski
msoffietti
here you the file
good work
bye
Artur.Kosakowski
Autodesk Support
Autodesk Support
As far as I can see the connections lost their synchronization with the model. You can either:
- recalculate the model which will update the connections with correct values of forces and then run verification again
or
- update connections and verify them again
Artur Kosakowski
