- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Colleagues
Here is an attachment file of multistory building. I want to design the Columns according to (ACI318-11).
But, I have faced some unclear points; I would like to clarify them from you:
1.Capture (000) for RC column (bar 20), How does Robot in required reinforcement calculate the value of (MZ) = 104.65 KN.m while in the analysis results only (4.37 KN.m). Knowing that I allowed buckling effect only in (Z-direction) (Length coefficient = 1)? May I know the equation to calculate this value?
2.Capture (001) for RC Column (bar 20), How does Robot also in provided reinforcement calculate the value of (MZ = 2980.90 KN.m) at the middle section of the column? It is very huge value.
3.Dose Robot in required reinforcement calculation for columns consider (the values of axial force and moments) of upper node when the buckling effect take in an account while treat with (the values of axial force and moments) of lower node when the bucking effect doesn’t take in an account?
4.Capture (002), what is the meaning of element type is “beam” while this bar is a column?
https://www.mediafire.com/?ji55n4im0t89k3h
Best Regards
Refaat
@Refaat Artur Kosakowski marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
