Add-ins
Add-ins
Message 1 of 8
Add-ins
Hello everyone
where can I find add-ins for Robot? I tried to look for in my account page but I diddn't find anything.
Actually I'm looking for the Idea Statica Connection's add-in but I don't really know where to find any add-in!
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
The link has been developed by IDEA RS. Please contact them for more information.
http://www.idea-rs.com
Artur Kosakowski
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Idea Statica 6.3.4 with link to RSA for connection design has been released and can be downloaded from:
http://www.idea-rs.com/downloads/
The way to add the link to Add-Ins command in RSA is described in the below link:
http://www.idea-rs.com/products-statica/idea-statica-steel/idea-statica-steel-bim/robot-link/
When you watch the movie available under the above link mind that you actually need to select both a node and elements you want to export. Mind that when you save a connection file with a space in its name you will need to manually open it in the Idea Statica Connection as the links only opens the application without the automatic connection transfer. If a file has got a name with no space the connection will be loaded automatically.
I have made a quick test sample to see how it works which you can see below:
Artur Kosakowski
Message 5 of 8
Rafacascudo
Artur ,
Are there Robot addins for Idea concrete and idea prestressing??
Couldn´t find on idea site
Rafael Medeiros
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not aware of any such links. On the other hand you should be able to export a model from RSA to Idea but I haven't tested this. You may want to post your question using this link:
info@idea-rs.com
Artur Kosakowski
Message 7 of 8
This is Juraj from IDEA RS. Appreciate fruitful discussion about our link!
Yes, it is correct that as of now, there is a link only between IDEA StatiCa Connection and RSA.
However, we are building on this to implement it also for IDEA StatiCa Concrete/Prestressing.
Drop me an email to juraj.sabatka@idea-rs.com and I will keep you updated on the progress
Juraj
Message 8 of 8
This is a long-closed discussion, but I am somewhat interested to know how Autodesk users or IDEA Statica users see the difference between using the RSA Connections module versus the IDEA Statica connections module. I have tried both. I found the RSA tool to be very well hidden, but once I got into it, it did everything I once considered IDEA Statica for.
Any discussion would surely be useful for future readers.
