API Tutorial
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Tutorial/td-p/3939601
Addin for displaying properties on selected only objects
Addin for Selecting Objects By Orientatio
Rounding up / down coordinates addin
Ordinary round coordinates addin
Macros for contour points modification and rounding
Macro for correcting nodes position by defining the path
Macro for rounding nodal coordinates
Models Comparison
http://forums.autodesk.com/t5/robot-structural-analysis/api-models-comparison-1-0/m-p/5651449
Macro for weeding \ removing intermediate points of panels
Addin for curtain walls cutting
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-wallcutter/m-p/5588636
Addin for intersection panels with each other
macro for creating panel profiles from bars
Addin for intersection/extension bars to plane
Merging bars addin
Merging panels addin
Addin for changing bar length by moving existing nodes
addin for bar offsetting = copying bars in LCS directions of bars
Addin for changing one bar node onto different one
Addin checking flatness of panels, contours, claddings
objects geometry to triangles converter
macro for converting panels to claddings
macro for creating 1 panel = 1 FE
Bars to Lines Converter addin
Lines to bars converter addin
Macro for Stories levels correction
Macro for geting and creating cartesian set of structural axes
Macro for highlighting nodes with instabilities
Addin and macro for detecting short calculation elements
addin for applying brackets on both sides of bars
macro for adding section in rsection dialog box
macro for Pile foundation generation
Macro: Creation of quasi T & L beams
addin for creating closest nodes between bars
Contourize is an add-on for Autodesk Robot that converts panel objects generated by the Extrude tool into normal contour panels.
Addin Bars Under The Curtain Walls
bars to rigid links converter
Spider - the multi-tool with rigid links
Diaphragmer - work with diaphragms in another way
Macro for replacing compatibilities existing in model for new one
Addin: Walls To Loads
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-Walls-To-Loads/td-p/4684075
Macro for creating superbars \ supermembers in Excel table
different manual combination table,
macro for adjusting combinatio
macro with inceremental buckling combination
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Buckling-combination/td-p/4331271
Converting nodal elastic support generated from planar support onto nodal support
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Editing-nodal-spring-values-API/td-p/3901799
Addin for changing bar forces with node generated load onto no node load.
Addin for coping loads for Load Cases
Macro - linear load converter to line load
Macro converting nodal loads onto force in point loads (for claddings, panels)
Addin: convert bar's forces to node forces
Addin for creating load cases basing on load records from another case
Macro for updating panel contour loads
Addin for multiplying all load cases records by factor
Macro for importing uniform panel loads from Excel to Robot
Macro damping Load table to Excel with single object list
Envelope of forces at a connection,
Macro for updating model geometry considering deformation of selected case
macro for bars strain calculations
macro for panels strains calculations
macro for nodal displacements in local coordinate system of bars
macro for bar end forces as reactions
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Local-reactions-API/td-p/3791474/page/2
different bars forces tables
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-max-moment/td-p/4762433
panels results tables
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RESULTS-EXPORT-VBA-API/td-p/4337588
Macro for dumping all opened tables in Robot (with all tabs) to Excel
Macro for dumping active table (with all tabs) to Excel replacing correctly "/"
sum of reactions for the slab on elastic ground defined in panel thickness definition
sum of reactions for the slab on elastic ground defined as planar support
Import of reactions to new model
Export / import reactions table to Excel
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-get-reactions/m-p/6575119
Nodes rotation – local axes
THA results to Excel
FRF results to Excel
macro for modifying the members list in steel design code groups in table
macro for creating Dimensioni
macro for checking bars membership in groups and steel design groups
macro for Member Verification ULS Ratio along bar length
Verification for the CFT column (Only circular tubular) and run all the optimizations based on construction costs.
addins for timber calculations, loads and combinatio
Addin for Exporting Reactions to Excel V2
Estimation of reinforcement weight for all RC Beams and RC Columns
(API) macro to send bar forces to excel in certain order
(API) macro for changing/multiplying load values by given coefficient
(API) Diaphragmer - work with diaphragms in another way
Exporting map of slab reinforcement
Storey Stability Index Calculation addin
Schemator - toolkit to manage External Parameters
Split Arcs - program to split all arcs of a contour, polyline
Sphere - to obtain spherical shapes from simple meshed panels by a translation of the nodes
