Panel Cut for only one Panel
ByrnePM
ByrnePM
Hi
Is it possible to have a panel cut only show the results for one panel which it cuts through;?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @ByrnePM
Select that panel and open it in the new window or click right mouse button and select Display for selection from context menu.
Krzysztof Wasik
ByrnePM
Thanks for the quick reply,
Is it also possible to examine the diagram analysis for only the one panel?
The integral/average values are impacted greatly by the other panels, unfortunately.
My particular case is examining panel cuts through a foundation raft slab underneath a concrete core - panel cut is cutting through the walls as well as the foundation
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @ByrnePM
Regarding your questions
Yes Diagram analysis is presented for selected panels.
Use smoothing within a panel (or no smoothing)  to reduce that effect.
Krzysztof Wasik
ByrnePM
Thanks again for your reply,
Just to help explain my query please see below snips
1 - Foundation under core with panel cuts
2 -  Diagram analysis view for SC2 - MID NS
You can see in Diagram analysis view that the core walls are being cut by the panel cut and are thus being capture in the overal integral/average results for this cut
Is there a way to just have the cut indicate information for the foundation panel?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Try to select required panel (foundation) before Diagram analysis generation.
Krzysztof Wasik
ByrnePM
Well that was simple ....sorted. Thanks Krzysztof!
