Composite sectione Result
Michele100100
Michele100100
Hello, I have  a concrete slab of 105mm C25/30 sitting on top of a IPE400 S355.
I would like to see Mechanical and geometrical results, so I did a composite section in Robot.
I'm interested in the neutral axis of the whole composite section, to check with my hands calculation.
Where can I read thsi value as distance from the top of the slab?
below the result, Thanks
Stephane.kapetanovic
HO @Michele100100
your calculation gives 60mm from top of slab and 445 from bottom of steel.
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Michele100100
hello,
did you refer to those values?
yes
Michele100100
