Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel Cut for only one Panel
6 REPLIES 6
ByrnePM
316 Views, 6 Replies
Hi
Is it possible to have a panel cut only show the results for one panel which it cuts through;?
6 REPLIES 6
Krzysztof_Wasik
in reply to: ByrnePM
Hi @ByrnePM
Select that panel and open it in the new window or click right mouse button and select Display for selection from context menu.
Krzysztof Wasik
ByrnePM
in reply to: Krzysztof_Wasik
Thanks for the quick reply,
Is it also possible to examine the diagram analysis for only the one panel?
The integral/average values are impacted greatly by the other panels, unfortunately.
My particular case is examining panel cuts through a foundation raft slab underneath a concrete core - panel cut is cutting through the walls as well as the foundation
Krzysztof_Wasik
Hi @ByrnePM
Regarding your questions
Yes Diagram analysis is presented for selected panels.
Use smoothing within a panel (or no smoothing)  to reduce that effect.
Krzysztof Wasik
ByrnePM
Thanks again for your reply,
Just to help explain my query please see below snips
1 - Foundation under core with panel cuts
2 -  Diagram analysis view for SC2 - MID NS
You can see in Diagram analysis view that the core walls are being cut by the panel cut and are thus being capture in the overal integral/average results for this cut
Is there a way to just have the cut indicate information for the foundation panel?
Krzysztof_Wasik
Try to select required panel (foundation) before Diagram analysis generation.
Krzysztof Wasik
ByrnePM
Well that was simple ....sorted. Thanks Krzysztof!
Technology Administrators
