Panel creation via API using cache
Hello to everyone,
I know that for creating nodes and bars there is the possibility to use the cache memory in VBA and then apply the allocated elements to the Robot model. This is a faster way of creating nodes and bars.
I would like to know if is there the same possibility for creating panels or, anyway, a faster procedure (faster considering the computational time) for creating panels.
Thank you in advance!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi Cris
Cache for panels is not implemented
Try:
RobApp.Interactive = False
RobApp.Project.Structure.Objects.BeginMultiOperation
RobApp.Project.Structure.Objects.EndMultiOperation
RobApp.Interactive = True
Example here:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-creating-panel-profiles...
Rafal Gaweda
