Edge load (API)
Edge load (API)
stathiseleftheriadis
Message 1 of 19
Edge load (API)
Is there a way to assign a linear load on a single edge (29_Edge(4) or a selection of slab edges with the API?
Replies (18)
Message 2 of 19
Romanich
As far as I know it is not possible to select a single edge like 29_Edge(4) via API.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 19
Initially, I thought it can be done like this
SDL = (RobotSimpleCase)Robapp.Project.Structure.Cases.Get(10);
// int IL_B = CaseIL.Records.New(IRobotLoadRecordType.I_LRT_UNIFORM);
LoadRecord = (RobotLoadRecord)SDL.Records.Get(1);
LoadRecord.SetValue(System.Convert.ToInt16(IRobotLinearOnEdgesRecordValues.I_LOERV_PX), 0);
LoadRecord.SetValue(System.Convert.ToInt16(IRobotLinearOnEdgesRecordValues.I_LOERV_PY), 0);
LoadRecord.SetValue(System.Convert.ToInt16(IRobotLinearOnEdgesRecordValues.I_LOERV_PZ), -1500);
LoadRecord.Objects.Add(EdgeSelection);
But I'm struggling to get the selection of edges.
I event tried
 LoadRecord.Objects.AddText("29_(4)");
But it's not working
Message 4 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @stathiseleftheriadis
Roman is right. It is not implemented in API.
Rafal Gaweda
Message 5 of 19
Thanks Rafal.
So as an alternative I'm creating small edge panels around the slab with height similar to slab thickness and then I apply FE Uniform load to those (which can be done in API). Do you think that would yield similar results?
Message 6 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear @stathiseleftheriadis
Exactly !
See example:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/error-2110-problem-with-linear-loads/...
But you may encounter this:
Objects not assigned to record if macro used more than one time on opened Robot
Rafal Gaweda
Message 7 of 19
Great. So far I haven't encountered any issues. I'm running it on a recursive algorithm in a case study with balcony loads. I run a test with more than 500 simulations and it was OK.
My only concern was the edge stiffness benefit due to the thickness of the panel but I reckon it would be minimal.
Message 8 of 19
Hi @stathiseleftheriadis and @Rafal.Gaweda,
Nice work around to solve the problem. I can create these edge panels along the boundary of the slab, but shouldn't I keep the thickness of these edge panels as less as possible ? Why did you take their thicknesses as equal to the thickness of the base slab?
Message 9 of 19
hi @stathiseleftheriadis and @Rafal.Gaweda, I am looking to apply my linear load on these edge panels.
Message 10 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
As @Romanich mentioned - fake bars there or add lines there and apply loads to them
Rafal Gaweda
Message 11 of 19
Hi @Rafal.Gaweda
str.Nodes.Create(1, 0, 0, BaseLevel + WallHeight);
str.Nodes.Create(2, 0, B, BaseLevel + WallHeight);
str.Nodes.Create(3, W, B, BaseLevel + WallHeight);
str.Nodes.Create(4, W, 0, BaseLevel + WallHeight);
str.Bars.Create(1, 1, 2);
str.Bars.Create(2, 2, 3);
str.Bars.Create(3, 3, 4);
str.Bars.Create(4, 4, 1);
/Apply dead load of roof slab
RobotSimpleCase deadweight_roof = str.Cases.CreateSimple(5, "Dead weight of roof", IRobotCaseNature.I_CN_PERMANENT, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR);
deadweight_roof.Records.New(IRobotLoadRecordType.I_LRT_UNIFORM);
IRobotLoadRecord2 LoadRec4 = deadweight_roof.Records.Get(1) as IRobotLoadRecord2;
LoadRec4.SetValue(2, -2000);
LoadRec4.SetValue(11, 1);
LoadRec4.Objects.FromText("1,2,3,4");
This doesn't throw an error. But it doesn't reflect the loading either. I am unable to figure out where I have gone wrong
Message 12 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Use :
LoadRec4.Objects.FromText("1 2 3 4");
instead of
Rafal Gaweda
Message 13 of 19
It doesn't work 😞
Message 14 of 19
Is it because I haven't initialised the bars?
Message 15 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Try :
RobotLoadRecord LoadRec4 =....
Rafal Gaweda
Message 16 of 19
Hi @Rafal.Gaweda,
Thank you for your reply. But it still doesn't work. 😞
Message 17 of 19
I found the bug. It should be I_LRT_BAR_UNIFORM  and not I_LRT_UNIFORM.
Message 18 of 19
Hi @Rafal.Gaweda and @Romanich,
How do I assign properties to the bars so that the overall effect on my calculations is minimum? (since the bars shouldn't technically be there in the first place). Any suggestions are welcome
Message 19 of 19
I am facing the same problem. Can you please share me how you added the edge in your code ..
