Nodes management
Nodes management
jo2ny
Message 1 of 9
Nodes management
jo2ny
I have a question regarding nodes.
1) Is there a way to select only nodes that are on bars, but not the start point or end point. I would like to get rid of them. Nodes that have only one adjoining member.
And what's the difference between adjoining members and adjoining elements
2) Can I generate nodes at intersections of bars without dividing the bars for the whole structure? As using the Intersection command but without bar division.
Thank you in advance!
Replies (8)
Message 2 of 9
1)Just drag the cursor box over the nodes you want to delete and press "delete".  As long as you dont actually select the bar, the bar won't be deleted.
2)See pic
Message 3 of 9
jo2ny
Yes, what you're saying is correct. But there are two problems here:
1) Dividing bars it's not needed at equal distances. This is not such a big problem because I can use the Divide by Plane option.
2) The big problem is what will I do if I have a bigger structure.
Here's an example:
In TOP view:
I have 30 vertical bars (Y direction). And another 10 bars that should be horizontal but after importing I found some of them a bit rotated (about 3 degrees angle from horizontal X direction). Probably due to some poor snaps in AutoCAD.
I deleted the bad horizontal bars, but the nodes from intersections remain. I want to select all of them and delete them. Preferably with a selection filter. - This is problem 1.
Secondly I will draw the 10 horizontal bars (in the correct position) and would like Robot to generate nodes at the intersections with the vertical bars. - Problem 2.
Message 4 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
If they are not on any bar (disjointed \ separated) just run calculations and they should be reported as Isolated Nodes, then  select them by group $NODISOL and remove. Or just only run Verification to detect some of them or add new bars and run Detailed Correction to line = bar or plane.
If it is not the case please make screen capture or send sample.
   - add nodes manually snaping to these points
   - calculation nodes can generated automatically at these points due to these settings
Rafal Gaweda
Message 5 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Maybe this:
Rafal Gaweda
Message 6 of 9
jo2ny
I made a Jing video.
I'll try to identify some steps to make the video clearer.
1) See the model
2) Selecting the area of interest and opening it in a new window
3) Identifying the bars with problems. They should be horizontal and extended to the last vertical bar.
4) Showing that intermediary points do not have any adjoining members, or elements (I don't know the difference between those two)  => they are isolated nodes
At a previous attempt they had only one adjoining member - the horizontal bar => not isolated.
I mention that this model was created by directly opening a 3D .dxf file created in AutoCAD.
Modifying in AutoCAD and reimporting is not an option because of numerous section attribution and member types that I made and don't want to redo.
5) I fixed the horizontal bars. Brought them to the correct position.
6) Generating a computational model. But there were no nodes generated at intersections. Why is that?
7) I'm trying to create some claddings. Cannot snap at the intersection of bars. Why?
All points and bars in this substructure are at Z=0.00m  so they should be in the same plane.
(I checked and also in AutoCAD in the 3D .dxf model, they intersect there also.)
Here's the video link http://screencast.com/t/86PK582vuIxB
Thank you in advance.
Message 7 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Whether these nodes are reported as isolated or not depends on Model Generation. If verification is run before Model Generation they can be reported as isolated. To be sure - turn on display of calculation elements.
Link to movie below. This is my way of correcting model:
http://screencast.com/t/6rmv6zyl
 There were, but calculation nodes, not real ones. Movie below.
 http://screencast.com/t/2BLqaw5C
Something with snapping... I will check
Workaround:  http://screencast.com/t/5U3THL4A
Rafal Gaweda
Message 8 of 9
jo2ny
Thank you! This helped me a lot!
It works nicely, this video explanation method.
It's very clear, and I think also easier than to explain in words.
Message 9 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
I guess it is related to calculation nodes there.
Easier workaround: http://screencast.com/t/M8tV5NoP
Rafal Gaweda
