New Section
New Section
New Section
I am trying to create a new section in Robot. I already read other topics about this subject, and I realized that I have to create it in an dxf file and import to Robot. But I don't know the process, do I need to create an specific layer or something in Autocad? And i didn't understand how I can import and save in the database.
Help would be very apreciated!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example movie with different approaches
(to use section in steel desing please select correct section symbol under question mark field and specify correct data)
Rafal Gaweda
Thank you very much! I just created a section and altough I had some troubles, it is working fine. I just have one more question, what are those dimensions in the saving section to database window? I attached a picture of this window.
Rafacascudo
These are to distinguish one section from another of the same type.
You can use all the 3 dimensions like  BOX(name) 300(d1) x 200(d2) x 25(d3) = Box 300x200x25
or just 2 dimensions (d1 and d3) - BOX 300x25
Rafael Medeiros
exelent
