Spring elements in Robot Structural Analysis
Hello.
I have the following question: it is possible in Robot Structural Analysis define spring elements, connecting two nodes of different bars (like in the image attached)? I want to connect two points of different elements, which are connected with a certain stiffness (in my case, translational stiffnesses).
Thanks in advance.
Ricardo Dias.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Connect node 1 with node 2
Use elastic bar release(s) on beam or column
Rafal Gaweda
I thought about that possibility, but in my case I want to have a certain eccentricity between the nodes.
For instance: I have two vertical bars, connected with bolts, side by side. Because their gravity center is different, I have to simulate them with an eccentricity. Is this possible to simulate in Robot?
I want to have the behavior of the bars bolted together, with a certain stiffness. In this case, the spring elements are to simulate the bolted connection.
Thank you.
Ricardo Dias.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Connect node 1 and node 2 with rigid link, add elastic release(s) on beam \ column.
If I understood you correctly:
- bolt - as bar with rather high stiffness - you will not loot at results in them
- elastic release(s) on bolts with correct spring values
Rafal Gaweda
