Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
moments from columns
8 REPLIES 8
Message 1 of 9
700 Views, 8 Replies
please tell me that the plate rests freely on three beams, and the edges on two walls, pass through the column, how to get rid of points emerging from the pillars? thanks for the help.
8 REPLIES 8
Message 2 of 9
Refaat
Hi
If I understand you correctly.
Refaat
Message 3 of 9
in reply to: Refaat
not quite
Message 4 of 9
Refaat
Hi
Could you add more explanations for (how to get rid of points emerging from the pillars? ) and capture if possible .
Refaat
Message 5 of 9
in reply to: Refaat
it is necessary that the plate does not interact with the column, i.e. the result should be similar to the one in which we have a bearing wall. send a screenshot
Message 6 of 9
Rafacascudo
As you have already been told in another thread , to have a similar result as in the model with bearing walls ,you will need to have beams as vertically stiff as those walls . If the beams are not that stiff , they will deflect and the "next" stiffer points will be the columns  which will be the reason for those peak values near their top node.
It´s not a model problem.
Rafael Medeiros
Message 7 of 9
in reply to: Rafacascudo
but I don't quite understand how to do it practically.
Message 8 of 9
Refaat
Hi
IMHO that the stresses at the column location due to the support is point support while as the stresses at the wall location due to the support is linear support.
Anyway, you can use release or remove the slabs and use uniform distributions loads on beams.
Refaat
Message 9 of 9
in reply to: Refaat
thank you
