Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Buckling Analysis
10 REPLIES 10
Message 1 of 11
636 Views, 10 Replies
Buckling Analysis
Goodmorning,
I'm modelling a curved roof made of trapezoidal hollow sections and I'm performing some benchmark checks to better understand the behaviour. I used a simple base model imported from Autocad made of some straight lines that tries to approximate the curved shape. I defined the trapezoidal section and defined a member type to joint the members and obtain the correct buckling lenghts but, as I run calculations and look at the calculation note the buckling analysis is not performed. (red X)
Does anybody tell me why this happens or better, which is the correct procedure to perform buckling analisis of a multi member group?
Does the user defined trapezoidal hollow section have some calculation issue?
Thank you,
Francesco
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
File please.
Rafal Gaweda
Message 3 of 11
in reply to: Rafal.Gaweda
Tks
Message 4 of 11
Rafal.Gaweda
It will not work with these Automatic Buckling settings.
See help:
http://help.autodesk.com/view/RSAPRO/2016/ENU/?guid=GUID-07FF6757-9008-47EC-B497-A4CD862BCFE2
Rafal Gaweda
Message 5 of 11
Ok, there's a lot of theory behind the automatic calculation of buckling coefficients but even in the enclosed file I cannot undestand how Robot calculates the parameters: these, compared to my hand calculations, are completely different. Where's my fault?
Message 6 of 11
Rafal.Gaweda
See webinar 3, slide 16
"For columns in regular buildings you may use automatic buckling length option which calculates buckling length coefficient for a column based on the stiffness of elements which are defined in its top and bottom nodes."
Additionally - think about correctly creating superbars
See webinar 3, slide 7
Rafal Gaweda
Message 7 of 11
Neither the load case that is considered as verification load case seems to be the worst one...
Message 8 of 11
Sorry for asking for further explanatios again, but it's completly unclear to me what webinar tries to explain and what I have to do to create and to use "superbars", (is it a member of members?).
Isn't there any simpler tutorial that can explain clearly what are the steps to follow to create a member made of smaller members, how to connect them to perform a correct buckling analysis and how to run the analysis on the worst load combination? I'm so sorry, it's surely my fault but as far as I can see, this type of anaysis is completely incomprehensible from the webinar and from the Robot's interface.
Message 10 of 11
DennisVDijk
I made superbars in your model, BAR 5001to5006.
Buckling length can also be determand by the following:
I hope this would help you. Attached is your model with superbars.
Good Luck!
Kind regards,
A&I│KWANT
adviseurs & ingenieurs
Dennis van Dijk
Structural engineer
www.ibkwant.nl
Message 11 of 11
in reply to: DennisVDijk
Thank you, finally I understood what I've to do!!!
