Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Modeling a cantilever floor
6 REPLIES 6
950 Views, 6 Replies
i want to model this cantilever floor from the edge of the beam and not from its center line in ROBOT, is this possible?
notice also the eccentric connection between the columns and the beam
6 REPLIES 6
Rafal.Gaweda
I guess you need to use rigid links to connect slab with beam and columns in the way you want to have it modeled.
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
This tool may help you a little:
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-spider-the-multi-tool-with-rigid-l...
see part of video related to Beam tab
Rafal Gaweda
couldn't find help in the video.
i do model the columns, then model the beam, and then finally i define the beam offset from the center of the column to model the eccentric connection between both, but when i define a cladding, the program just applies it to the center of column as if there was not an eccentric connection.
Rafal.Gaweda
I did not say anything about offsets
Rafal Gaweda
Rafacascudo
I think that what you need and Rafal was trying to tell you is something like this.
No offsets at all. Everything done with full rigid links. Top of the columms nodes linked to the beams end nodes.
Nodes along the beams also rigidly linked to panel edge nodes.
sample model attached
Rafael Medeiros
Rafal.Gaweda
in reply to: Rafacascudo
Exactly 🙂
Rafal Gaweda
Technology Administrators
