Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Meshing errors
1 REPLY 1
525 Views, 1 Reply
Meshing errors
Hello!
I have problems with my meshing. I'm getting 2 different types of errors. First one says "Model error - a cyclic reference in the definition of kinematic constraints" and to solve that i followed the instructions that were on https://forums.autodesk.com/t5/robot-structural-analysis-forum/cyclic-reference-problem/td-p/3737643 this page. After doing so this error is gone but now i keep getting other error that says " Incoherent mesh on edges" and i cant find the solution to that, cause the on that i found https://forums.autodesk.com/t5/robot-structural-analysis-forum/structure-verification/m-p/3334637/hi... doesn't work for me.  Can someone please help me 🙂 i have also added the model.
1 REPLY 1
Krzysztof_Wasik
i @Anonymous
Meshing problems are caused by not precisely defined geometry
I have corrected your model
  • defined additional Structural Axes and corrected geometry using them as reference points (staircase region)
  • deleted duplicated panels  42 49 66
  • corrected panel 53 defining its edge 3 along wall 55
  • corrected linear load position for panel 53 edge 3
  • I have removed not necessary releases  from supported columns (instability type 1)
I was not able to correct all not precisely defined objects so while meshing
  • I have meshed all panels first
  • then due to incoherences I remeshed walls on grid axis 4
  • then I remeshed wall 53
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
