Hello!
I have problems with my meshing. I'm getting 2 different types of errors. First one says "Model error - a cyclic reference in the definition of kinematic constraints" and to solve that i followed the instructions that were on https://forums.autodesk.com/t5/robot-structural-analysis-forum/cyclic-reference-problem/td-p/3737643 this page. After doing so this error is gone but now i keep getting other error that says " Incoherent mesh on edges" and i cant find the solution to that, cause the on that i found https://forums.autodesk.com/t5/robot-structural-analysis-forum/structure-verification/m-p/3334637/hi... doesn't work for me. Can someone please help me 🙂 i have also added the model.
Solved by Krzysztof_Wasik. Go to Solution.
i @Anonymous
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
