Instability (of type 3)
Message 1 of 9
Hello there,
I have constructed a model for a helical stair design on robot but I am having an issue resolving a type 3 failure at 1 particular node. This tends to be located at the mid-flight landing or at the very top of the stair. I have attached a picture to highlight this. Essentially I am wondering if this will have a significant impact on my results and if so is there any way to fix it? Any help would be much appreciated.
Kind Regards
Mark
Replies (8)
Message 2 of 9
Hello there,
Kind Regards
Mark
Message 3 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 4 of 9
Hello there,
I have constructed a model for a helical stair design on robot but I am having an issue resolving a type 3 failure at 1 particular node. This tends to be located at the mid-flight landing or at the very top of the stair. I have attached a picture to highlight this. Essentially I am wondering if this will have a significant impact on my results and if so is there any way to fix it? Any help would be much appreciated. I should also add that if I decrease the number of divisions of my mesh, the failure message changes from type 3 to type 2.
Kind Regards
Mark
Message 5 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 6 of 9
Apologies,
My computer crashed each time I tried to post and I was unaware it had worked. I will try this method and let you know how I get on.
Thanks very much
Mark
Message 7 of 9
Apologies but the issue still has not been resolved using the skyline solver as I am still getting a type 3 failure.
Would it be possible for you to have a look at the model and advise me on the best possible solution?
Thanks again for all your help!
Regards
Mark
Message 8 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, post \ send us the model
Rafal Gaweda
Message 9 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Correct model size first
Rafal Gaweda
