How to design Concrete column-steel beam connection?
Regards to all, my question is how to analyze a concrete column connection to steel beam
Note:
I use Robot Structural 2015 and Revit 2017
@Anonymous I edited the topic for better findability and marked your post as the solution. Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
What kind of analysis do you mean exactly?
Artur Kosakowski
Steel connections with concrete column, but I already solved it. I take it as a foundation and I give you the measures that my column can support
How did you add the plate between the Concrete Column and Steel Beam in Revit. And also what kind of connection did you use?
Hello @mustafahesenow how are you? Reviving this topic, do you have any other recommendation for this type of connection STEEL BEAM-REINFORCED CONCRETE COLUMN? is any other way to get it in RSA? How can you recommend to calculate it? or how do you calculate it in your projects?... should be calculated as a fixed or pinned connection? What do you thing solving it as a foundation as @Anonymous suggest? Thanks in advance for your response.
@Artur.Kosakowski what do you think about this solution? Is any other way to calculate it in the software? Pinned or fixed support? Thanks in advance for your response.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If you want to design such connection type in Robot then it is the only option. I think it makes sense but of course you should disregard the part with anchor verification in the foundation and do this part by hand as most likely you will use some other 'anchorage' type.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
