How to connect two continuous beams (purlin - rafter connection)?
36 REPLIES 36
Message 1 of 37
4963 Views, 36 Replies
I was looking for a solution to make an articulated union between the pink beams  and yellow beams  in the intersection nodes. Note that I want the pink beams to be continuous and the same with the yellow beams, so finally I have 4 pink beams and 2 yellow beams. I´ve read about releases but I think it doesn´t work for this case as i want the beams to be continuous. Should I do it with compatible nodes?
@Anonymous Artur Kosakowski edited the topic for better findability
36 REPLIES 36
Message 2 of 37
Artur.Kosakowski
You should define compatible nodes. Please check these topics:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/compatible-nodes/m-p/3689964
https://forums.autodesk.com/t5/robot-structural-analysis-forum/compatible-nodes/m-p/3797147
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 37
in reply to: Artur.Kosakowski
Ok, so I´ve done with compatible nodes as you said me. In the images below you can see how I´ve done it. Could you please check it?
As I want to block that degrees of freedom in the local Coordinate System of Pink Beam I think I should enter the Alpha Beta and Gamma angles
Are these angles defined as you can see in the last image . That´s how I understand that angles.
Last question, would this compatible nodes work if I introduce an Offset to one or both of these beams?
Thank you.
Message 4 of 37
Artur.Kosakowski
Mind that the degrees of freedom are referring to the global coordinate system so your understanding of rotations is correct but you should block RZ instead of RX (I assume you want to block in-beam plane rotations and the pink one are parallel to the global X). I'd rather not use offsets but define beams on different levels with connections done via rigid links instead.
Artur Kosakowski
Message 5 of 37
But if I define the alpha, beta and gamma angles for the pink local system then I´m blocking that degrees of freedom in that local system right?
Both beams are not parallel to the floor.
If I don´t block the RX Robot gives me inestability warnings. Finally you´re right, I will block RZ also as both beams should rotate in the same way respect the Z pink local axis.
Message 6 of 37
Artur.Kosakowski
In general for this type of connection you just block displacements so that there is no need to rotate the compatibility as there is no such need (applied load will not cause any significant rotations in planes other than the parallel to the local Z of beams). I'd check what other boundary conditions are (perhaps you allowed beams to rotate about their own axes at both end supports or defined such releases).
Artur Kosakowski
Message 7 of 37
1.-Please find attached the example, If you try to calculate the model without blocking RX you have inestability, that´s why I´ve blocked it. I´ve used compatible nodes and i´ve blocked degrees of freedom respect local system as you can see.
2.-I would need to place the horizontal beams above the others. As you said you wouldn´t use offset, so how can I do it with rigid links?
Message 8 of 37
Artur.Kosakowski
Indeed as you have free ends for purlins you have to block RX. For connections among the columns and rafters you may use releases at the top column ends instead.
As for rigid links d.o.fs are in the global coordinate system with no option to rotate them I defined dummy bars with their local coordinate system as per lines of beams and defined releases at their top ends (the same principle would apply to rigid links where you release d.o.fs in the same way as I defined releases).
Artur Kosakowski
Message 9 of 37
ok, thank you Artur.
Why did you say you wouldn´t use compatible nodes and no offsets?
Could you please help me defining the code  parameters of the columns and beams in the same exercise in order to verify the structure please? I´m not sure if I´m doing it well.
Thank you again.
Message 10 of 37
Really good questions b28.
I have the same type of problems in one of my structures.
If I use rigid links it gives me Inestabilyti (Blocking UX UY and UZ and RX ) and i Can not see information.
Wich is the difference between using rigid links and using compatible nodes with offsets as "b28" said ?
Message 11 of 37
Artur.Kosakowski
As in offsets you 'move' a bar without moving nodes you may get inaccurate values of forces which was already discussed both on the forum and during Robot webinars e.g. check Offset in Beam
@AnonymousIf I use rigid links it gives me Inestabilyti (Blocking UX UY and UZ and RX ) and i Can not see information.
Please create a new topic for this issue and attach your model.
@Anonymous Could you please help me defining the code  parameters of the columns and beams in the same exercise in order to verify the structure please? I´m not sure if I´m doing it well.
Please create a new topic for this question and confirm that outer parts of magenta beams (e.g. bar 1) are indeed cantilevers.
Artur Kosakowski
Message 12 of 37
Ok, thank you Artur.
Message 13 of 37
Hello again Artur, I´m doing a similar case to this one and I´m doing it without offsets, using rigid links as you told me. I prefer doing it with rigid links instead of using dummy bars with releases in order not to have a lot of beams. The problema is that even if I blocked de 6 dof in the rigid link I still have inestabilities. How can it be posible? How can I get no inestabilities? I just want to make and articulated union as in the old example.
I attach some images so it´s easier to understand the prblem.
Thank you.
Message 14 of 37
Artur.Kosakowski
Hi @Anonymous,
I will not be able to tell without ruining your model. Could you attach it?
Artur Kosakowski
Message 15 of 37
Sure, please find it attach. I want to make an articulated union where a rigid link is placed. But I have inestability even if I block the 6 dof. I have noticed that if I change the Z section (I´ve made it) for another section, this problem disappears. However, when I block only the traslations I have inestability no matter the sections are.
Message 16 of 37
Thank you
Message 17 of 37
Artur.Kosakowski
Hi @Anonymous
If you change the solver to Skyline there is no instability which suggests just a difference in stiffness of elements of the stiffness matrix caused by using RLink elements for Rigid links (required for Sparse and MKL solvers).
I hope this helps.
Artur Kosakowski
Message 18 of 37
Hi Artur,
I changed to Skyline and there is still inestability when I block only the translations. I´m using my own sections, could this be a problem?
Thank you.
Message 19 of 37
Artur.Kosakowski
Hi @Anonymous
Try to keep Skyline but unmark RLinks.
Artur Kosakowski
Message 20 of 37
Hi Artur,
I tried without marking RLINK but it still gives me inestability.
Technology Administrators
