Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Compatible nodes
1 REPLY 1
stroxy
1395 Views, 1 Reply
Compatible nodes
In an RC slab and beam floor, do I need to define the junction of primary beam/secondary beam with compatible nodes (to have same deflection)? Or does the option create a node at the junction of horizontal and vertical bars in the "analysis types" dialog take care of this?
1 REPLY 1
Artur.Kosakowski
in reply to: stroxy
The 'use' of either of them depends on what kind of the connection this is. The latter is just kid of the connection you have e.g. between a primary and a secondary beam in a grillage system whereas compatible nodes are most likely to be used for a rafter - purlin connection or for bracings (see:
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-774B172C-7704-4D88-8830-DBE3D05FD6C1.htm?highl...
Artur Kosakowski
Technology Administrators
