how to change combination types
TSOFA
TSOFA
Hi all,
I created a number of combinations with excel spreadsheet and I copied the combinations to "combination table". The problem is that I created combinations of ULS, SLS and ACC but when I copied them to robot they were all copied as SLS. How can I change the combination type for many combinations at the same time? there are 149 combinations, so if I do that one by one will take for ages.
Thank you in advance.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TSOFA
Try to follow the steps shown below:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
TSOFA
that's great!! the problem was that at the tab of combination table that you can correct the combinations I didn't have the column of "combination type"! Now I corrected that and I can follow your solution
thanks again!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TSOFA
I'm glad I was able to help. Next time add this column in Excel and display it in RSA before pasting and you should have no issues with the combination types.
Artur Kosakowski
ArunNDinesh
Thank you
