How can I know if there is tension or compression in the top of these beams?
yiviw97057
yiviw97057
I have varying local axis for my beams, and I am not sure how to tell if the beam is being bent downwards or upwards. I know about the right hand rule, but from the grapsh you see below, is there a way to tell if the beam is tension or compression at the top of the beam?
Romanich
Hi @yiviw97057 ,
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
yiviw97057
Would you say there is tension or compression over the support? Notice the local axis vary from global ones
Romanich
Hi @yiviw97057 ,
Top fibers in tension, bottom fibers in compression
Roman Zhelezniak
