Beam Design in Eurocode
Hi, I'm try to design a beam with stiffeners in Eurocode. When I assign the default beam member type, the ULS design goes on to fail but however interestingly, if I click on the failed member to check the calc note and then select detailed design, the beam passes even without stiffeners (See pictures). As a result, I have two questions:
1) What is the function of detailed design and how is it different from conventional design?
2) How can I design a beam that has stiffeners in Eurocode.
Please find attached the link to the model and also some pictures.
