Message - Linear load has not been applied to panel
Kevin.VillanuevaNYJQV
Observer Observer
Observer
Observer
Hi all,
I am getting the following error/message - 'Linear load has not been applied to panel'. but I do not know how to solve it.
I modelled the Water tank walls using two arcs and extruding them create the walls. Then, I created the openings using object combination, and applied the loads. I decided to apply the roof load using linear loads at the top edges of the wall/panel so i could simplified the model.  However, I am getting this messages every time i run the model.
I try deleting the loads and the panel and creating them again, but I keep getting the same message.
Could someone help me?
makFD9ZD
When you create arcs select discretization option, after that extrude and apply linear loads on edges.
Observer
Observer
Many thanks for your comment makFD9DZ.
I tried your steps but, unfortunately, it did not work - I am getting the same message.
I think it is related with the creation of the openings.
Do you have any other suggestion?
Cheers
Romanich
Hi @Kevin.VillanuevaNYJQV ,
Try to exclude this object from the load distribution, i.e. assign the line load only to the tank walls
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
okapawal
The warning message may be incorrect.
Looking at sum of FZ reactions and global displacement it seems that the linear load is applied to the edge.
Pay attention to the hydrostatic pressure load.
I would swap Z direction on panel 58 to read results coherently in local direction
and then change the water weight from -1000 (kG/m3) to plus value.
Waldemar Okapa
Sr Product Owner
Krzysztof_Wasik
Autodesk Support
Autodesk Support
In that case I would recommend define arc discretized according to generated mesh (22 segments) along top cylinder edge, and apply load to this arc
Refer to video
Krzysztof Wasik
