Gridshell model
Gridshell model
Message 1 of 29
Gridshell model
Hello!
I would like to ask for some help with my model. I’m working on a gridshell structure and I’m having some troubles rotating the bars in a way that it follows the inherent surface. The problem is that the rotation angles varies in length so if I rotate the whole lath that will not work… and I have almost 2000 little bars, it is crazy to rotate one by one… I’ve tried everything without success.
I attach a pic from the model in Rhino, with laths following the surface, and the robot model;  As you can see, I already rotated some of the bars manually.
I hope I was clear with my question J
I want to thank you in advance!
Best regards,
David
Replies (28)
Message 2 of 29
Rafacascudo
  Very hard to do it because the continuous beams are not even in a same plane. They are 3D.
And you´ll have an additional problem . The beams don´t cross each other at the same coordinate. There´s always  a 5cm offset between them. If you mantain this geometry you´ll have to set some rigid links between these 2 "crossing" nodes.
  How did you import this model from Rhino??
Maybe some of the file types that Robot can open are better suited for this import.Check if Rhino can export to one of these file types.
SSDNF files keep the original gamma angle . Even if robot doesn´t recognize the Rhino section  , you can assign it later. The important thing is getting the correct gamma angle as you open the imported file in robot.
Rafael Medeiros
Message 3 of 29
Thank you so much for your quick response!
I saved rhino model in a DWG file and then I assigned the section in Robot.
I was checking Rhino "Save as..." options and I could find the SSDNF file type. That would be great if I could keep gamma angle, the problem would be solved! Do you know if there is another file type which would be equivalent?
Message 4 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
create node in the "dome center" \ "center" then Geometry \ Properties \ Gamma Angle -> Node and use this node number as a reference
Rafal Gaweda
Message 5 of 29
Rafacascudo
Maybe .SAT file  or CIS/2 format(.stp). Check the file formats that Robot can open on the picture I sent on the previous post!!!
This is what is supported by Rhinoceros
Or a triangular operation using Revit , or SketchUP .
Rafael Medeiros
Message 6 of 29
Thank you so much for your suggestion Rafal.Gaweda!
When you say dome center do you mean the center point in the surface or taking the dome as a solid object and then the gravity center?
thanks!
Message 7 of 29
In the last post, I forgot to tell you that I've tried all of the suported files in Robot... The best one is SAT. file, but still have the same problem.
Message 8 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 9 of 29
Rafacascudo
Rafal ,
I don´t think it is a sphere
Rafael Medeiros
Message 10 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
It does not matter sphere or elipsoid for my idea
It does matter that "beams" are wavy ; each meridian and parallel is not made in plane.
Good luck
Rafal Gaweda
Message 11 of 29
Rafacascudo
Rafal ,
By the picture he sent on the 1st post , it seems that the beams are supposed to have one local axis perpendicular to the shell surface.
This gamma angle "node" solution " seems " to work for the higher " arches" but the below picture shows that it does not.
Rafael Medeiros
Message 12 of 29
Rafacascudo,
When I initally applied Rafa.Gaweda solution I had the same problem, but then I understood why... As you can see in the pic I send, the original surface that generated this structure it is different. I used the center point of that big ellipsoid, applied gamma angle and then I just rotated 90º and now it's working!!! 🙂 there are some little errors but not relevant!
Thank you so much for your help Rafacascudo and Rafa.Gaweda!!
Best regards 😉
David
Message 13 of 29
I forgot the picture!
Message 14 of 29
Rafacascudo
David ,
The geometrical center of the big elipsoid as reference node for gamma angle  will never give you the exact solution.
If your elipsoid approaches a sphere , it will " seem" that the bars orientations are correct.
It is clear by the picture below , that the shell surface will be perpendicular to the elipsoid center only at 0 , 90, 180 and 270 degrees
Rafael Medeiros
Message 15 of 29
Rafacusdo,
I understand it now!! you're right... thats why I see some little errors! In this case it might be not relevant, but if I need to change the surface it can be important.
I was trying to understand by the image you sent me if there is other option...Any idea?
Thank you a lot,
David
Message 16 of 29
Rafacascudo
  I think the solutions within robot will be also aproximations. Best option ,in my opinion ,would still be getting the bars correct gamma angles through the imported file.
  I see by the name of your Robot file , does it comes from SCIA enginneer software??If yes , can it export to one of the formats that Robot can open?
Rafael Medeiros
Message 17 of 29
From what I can see now, central point it is not the solution at all...
Scia appears in the file name because after struggling so much with this problem in robot I tried Scia engineer but the problem is exactly the same...The original file was the same, it is a DWG file exported from Rhino... so forget the name, it might induce in error.
I'm gonna try to check more about importing files keeping the same gamma angle...
Thank you a lot Rafacascudo!
David
Message 18 of 29
I advice you to use grasshopper to solve your problem.
Here attached is a little definition which might help you.
First check on GHX that your angle are correct using SDL line.
Second copy/paste, or use API GHX/RSA to inform the angle in the bar tab,
Then chack visually on preview.
It should work fine. Tell me if you have any difficulty.
Once you've done it, there is another issue, getting the displacemnts into the local coordinates.
Here below an study cas on Bordeaux's Cité du Vin.
Global gamma orientation
Local Global orientation
Here another definition, maybe RSA could integrate it in RSA 2018 ?
Message 19 of 29
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 20 of 29
Rafacascudo
Awesome!!!
Done in Robot??
Rafael Medeiros
