Gridshell model
Gridshell model
Message 1 of 29
Gridshell model
Hello!
I would like to ask for some help with my model. I’m working on a gridshell structure and I’m having some troubles rotating the bars in a way that it follows the inherent surface. The problem is that the rotation angles varies in length so if I rotate the whole lath that will not work… and I have almost 2000 little bars, it is crazy to rotate one by one… I’ve tried everything without success.
I attach a pic from the model in Rhino, with laths following the surface, and the robot model;  As you can see, I already rotated some of the bars manually.
I hope I was clear with my question J
I want to thank you in advance!
Best regards,
David
Replies (28)
Message 21 of 29
For those who would be interested,
Here below is a presentation on the Cité du Vin :
Fichiers (24 Mo au total)
Presentation_CCV_170119_0.pdf
Disponible jusqu'à
28 février 2017
Lien de téléchargement
https://wetransfer.com/downloads/621393a87dc11c91e10078301e22c03c20170221095337/c98bef
Message 22 of 29
Dear Sir/madam,
At the moment I am writing my thesis for structural engineering about a timber gridshell design. I came across this discussion and your contribution about the Cité du Vin. Is it possibile to still get a copy of your presentation of this project? I think it is quite marvelous.
best regards
Message 23 of 29
Rafacascudo
It should go to Robot art galery!!!!!Smiley Wink
Rafael Medeiros
Message 24 of 29
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Thank you for sharing your presentation but the link you provided has already expired. Perhaps you could attach the pdf directly to your post?
Artur Kosakowski
Message 25 of 29
Dear all,
Here is the Cite du Vin updated link, the pdf is too heavy to bet downloaded, sorry.
I added a presentation on Quaternion's elastic gridshells too, and a lecture we gave to architectural students on parametric structures.
Good bye
https://wetransfer.com/downloads/0e22e0f3f122b504c1b967765bf0086620171002124753/41017cbb4b0b76f42c57...
Message 26 of 29
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm attaching the pdfs so that they are available after the link posted by @Anonymous (thank you) expires.
Artur Kosakowski
Message 27 of 29
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm attaching the pdfs so that they are available after the link posted by @L (thank you) expires.
Artur Kosakowski
Message 28 of 29
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 29 of 29
Hi everyone,
For a upcoming schooltrip to Bordeaux, I need to have the 3D drawings of Cité du Vin.
Now I came across this post and I was wondering if any of you had the drawings or knows someone that has the drawings?
Thanks a lot in advance for the help!
