RC Module transfer error
Hi Artur
Please take a look at this file, it doesn't transfer the internal forces to the RC modul
Element 242 and 221
Even after opening in recovery mode the problem persists
Thanks in advance
http://we.tl/Pf3LxMXagV
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have checked on RSA 2016 SP1 and
- beam 221 is exported and calculated however it takes a bit of time to generate reinforcement
- beam 224 is not exported due to the fact that its web is too narrow. It has to be wider than 5in (should be at least 13 cm).
Artur Kosakowski
