Failed to open .rtd file
Hello, i have problem with my truss file(.rtd), i cannot open it. But when i try to close it it went blank and jammed. How do i recover it back?
Mohammed_Ata
Try to open it in the "repair mode"
Romanich
@Anonymous are you sure that the file was created in the same version of Robot? For example, it is not possible to open rtd file created in Robot 2018 using previous versions of the Robot.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach this file?
Artur Kosakowski
here is my file as attached.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The file as suggested by @Mohammed_Ata (thank you) can be opened in the repair mode. To see the model switch off the display of supports and then set the 3D view and press the Zoom All button.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
