API capture view of active window
jmmarin
Message 1 of 9
jmmarin
I have found some posts regarding the capture views directly to the clip board. What I need to do is to capture the active view (I will have show in the active view what I need: maps, geometry, ...). The code I am trying is the following, but it only captures the general view of the structure, not the active window.
I would appreciate some help.
Regards.
Sub capturaimagenRobot()
' définition d'une vue
Set RobApp = New RobotApplication
RobApp.Interactive = True
RobApp.Visible = True
RobApp.Window.Activate
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = RobApp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
'ScPar.Name = "Screen capture"
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
ScPar.Resolution = I_VSCR_2048
mavueRobot.MakeScreenCapture ScPar
ActiveCell.Select
ActiveSheet.Paste
election.ShapeRange.ScaleWidth 0.36, msoFalse, msoScaleFromTopLeft
End Sub
Replies (8)
Message 2 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jmmarin
It is like that because you need to change view number in this \ such line:
Rafal Gaweda
Message 3 of 9
jmmarin
Hi Rafal,
Thank you for your reply.
If I put 1 as index, it is always captured the first view in the program, i.e. the “View” sheet of the model.
I think that I need to obtain the “index” of the active window but I do not know how to do it. I know it because if I try 1, I obtain the capture of the main view. Number 2, captures the second view. Number 3, the third one... and so on.
Message 4 of 9
jmmarin
Hi again,
I apologise for the misunderstanding in my previous post. I'm going to explain what I am trying to do. It seems simple, but I am beginner in the API of Robot and it is being impossible for me...
I want to generate the captions of certain results all from a Excel spreadsheet
In the above VBA code I get the capture of the view number 3 and for the selected cases. I need to do the same but for the active window in the model and for the cases that I specify in the spread sheet
For example: I specify in a cell of the spreadsheet that the cases I want to show are "1to10" and execute the macro. This macro must assume "1to10" as cases and capture (to the clipboard) the results which have been selected in the result dialog box the Robot.
I hope to have explain my problem. Thank you.
Message 5 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jmmarin
So you need to check first mavueRobot.Window.IsActive to get actvive window number, then get active view ,
then apply case selection to this view by mavueRobot.Selection.Set(I_OT_CASE).....
Rafal Gaweda
Message 6 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jmmarin
Sample code to get active view number:
Dim ActiveViewNumber As Integer
For i = 1 To Robapp.Project.ViewMngr.ViewCount
    If (Robapp.Project.ViewMngr.GetView(i).Window.IsActive <> 0) Then
        ActiveViewNumber = i
        Exit For
Next i
Set mavueRobot = Robapp.Project.ViewMngr.GetView(ActiveViewNumber)
Rafal Gaweda
Message 7 of 9
jmmarin
Thank you again for your patience, Rafal.
That portion solves to select the active view.
However, what I do not get is to set the group of combinations that I want to show in the graphic. I try the following code, but the graphic always shows the combination that I have selected in the program. I have defined "100to149" but it will be whatever.
I am sure I am missing something due to my lack of practice, so I apologise...
Set rselection = RobApp.Project.Structure.Selections.Create(I_OT_CASE)
rselection.AddText "100to149" 'For instance
Dim RCaseCol As RobotCaseCollection
Set RCaseCol = RobApp.Project.Structure.cases.GetMany(rselection)
Set mavueRobot = RobApp.Project.ViewMngr.GetView(<<here the variant with the active view>>)
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY
mavueRobot.ParamsFeMap.Direction = I_VFMLST_AUTOMATIC
mavueRobot.ParamsFeMap.WithDescription = True
mavueRobot.Redraw (0)
RobApp.Project.ViewMngr.Refresh
Message 8 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @jmmarin
As I wrote before ...Selection.Set....
        Exit For
Next i
Dim CaseSel As RobotSelection
Set CaseSel = Robapp.Project.Structure.Selections.Create(I_OT_CASE)
CaseSel.FromText "100to149"
mavueRobot.Selection.Set I_OT_CASE, CaseSel
Robapp.Project.ViewMngr.Refresh
Rafal Gaweda
Message 9 of 9
jmmarin
Thank you Rafal.
That is exactly what I needed, and now I have understood which my problem was...
