RSAP2018 nodes - Graphical problem
I have problem with display nodes.
When i turn on OPEN GL, nodes don't disappear when i use section planes.
When i turn off OPEN GL - it's ok. I had the same problems in RSAP2017 but in 2016 was ok.
I have Nvidia Quadro K630.
Try to reduce the display acceleration as far as your GPU can resolve the graphic issue
To turn off the OPEN GL option you must uncheck the box
(Sliding to None is to slow down)
Try with 3/4 of acceleration, often works well
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Corrected in the Update 1 for RSA 2019
Artur Kosakowski
