EXPORT ROBOT EXECUTION PLAN
wilfriedouskanGPULS
wilfriedouskanGPULS
Hello
I would like with solutions for exporting Robot execution plans.
When I try to export an execution plan for editing, the only available format is dxf. Once exported in dxf, the elements are no longer to scale, are in another color, shifted, etc.
Is there a way to export plans that keeps the display of elements clean?
Muhammed.OPERA
Hi @wilfriedouskanGPULS
See that post: https://forums.autodesk.com/t5/robot-structural-analysis-forum/export-a-3d-model-from-robot-to-autoc...
I think it's dealing with your problem, specially the last replies.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
wilfriedouskanGPULS
Thank you for your quick reply
However, he is trying to export a 3D model, I am trying to export an execution plan in another way without the rendering losing quality (display)... I would like once to export it to be the same as the presentation of Robot.
In the first image below: my plan once exported in dxf
In the second image below: the robot presentation (what I would like to obtain)
plan in dxfplan in dxfrobot presentationrobot presentation
Muhammed.OPERA
I got you now, all you are seeking is in "Drawing parameters" specially scale and colors of lines and line width as you can see here.
Facebook |LinkedIn
Muhammed.OPERA
Then you may have to do some changes in AutoCAD to change the used font for text from "Text style command" "ST"
and you can scale the whole drawing (Reference scale) with respect to any member you use as guide.
Facebook |LinkedIn
