Execution error 3060
Message 1 of 8
Could you please help solve execution error 3060 on this model attached in this post. Appreciate your help.
@Anonymous Artur Kosakowski marked posts as the solutions. If either of them did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I do not see any issue on file (meshed by me) ; Robot 2016 SP4.
Try attached file.
Rafal Gaweda
Message 3 of 8
Hi Rafal,
Thank you so much for that, I really appreciate it. Is it only a change in mesh setting that solved it? I posted here the old and new setting so others can refer.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I also changed I guess:
- model generation tolerance to 1mm
- no RLINKS
- no DSC
- iterative adjustment of FE mesh - ON (set before the remeshing)
Rafal Gaweda
Message 5 of 8
Hi Rafal,
I have again encountered execution problem 3060 on this model. Could you please help to solve? I followed the same meshing and done inputs according to the above list but can't find the reason why I keep getting this error. Thanks in advance for your help.
Rico
Message 6 of 8
Appreciate anyone who could help, thanks in advance
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Is it the same  There is no error 3060 when you block Rz in the definitions of the supports and RX in definition of the releases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 8 of 8
Hi, I have a problem "Execution problem No:3060". Really, I got tired and didn't get a solution! When I was used shell panel without stiffening, the calculation was very good and no problem. but when I converted my floors to shell panel with partial stiffening, this error showed "Execution problem No:3060".
