Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Execution error 3060
7 REPLIES 7
Message 1 of 8
3827 Views, 7 Replies
Could you please help solve execution error 3060 on this model attached in this post. Appreciate your help.
@Anonymous Artur Kosakowski marked posts as the solutions. If either of them did not work as an answer, please post your reply in this thread so that I can unmark the solution.
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Hi @Anonymous
I do not see any issue on file (meshed by me) ; Robot 2016 SP4.
Try attached file.
Rafal Gaweda
Message 3 of 8
in reply to: Rafal.Gaweda
Hi Rafal,
Thank you so much for that, I really appreciate it. Is it only a change in mesh setting that solved it? I posted here the old and new setting so others can refer.
Message 4 of 8
Rafal.Gaweda
Hi @Anonymous
I also changed I guess:
- model generation tolerance to 1mm
- no RLINKS
- no DSC
- iterative adjustment of FE mesh - ON (set before the remeshing)
Rafal Gaweda
Message 5 of 8
Hi Rafal,
I have again encountered execution problem 3060 on this model. Could you please help to solve? I followed the same meshing and done inputs according to the above list but can't find the reason why I keep getting this error. Thanks in advance for your help.
Rico
Message 6 of 8
Appreciate anyone who could help, thanks in advance
Message 7 of 8
Artur.Kosakowski
Hi @Anonymous
Is it the same  There is no error 3060 when you block Rz in the definitions of the supports and RX in definition of the releases.
Artur Kosakowski
Message 8 of 8
in reply to: Artur.Kosakowski
Hi, I have a problem "Execution problem No:3060". Really, I got tired and didn't get a solution! When I was used shell panel without stiffening, the calculation was very good and no problem. but when I converted my floors to shell panel with partial stiffening, this error showed "Execution problem No:3060".
