Element not assigned to story
Message 1 of 12
I have read the postsCapture.PNG on this subject and have tried to redefine the stories to assign columns to stories.  I have a 3 story structure that was created in Revit.  After redefining the stories, the upper level columns have been assigned but the lower level have not.  What else can I try?
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to run model correction to structural axes with e.g. 0.5 m tolerance and then run automatic assignment of elements to stories.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 12
Thank you Artur for all your help.  I appreciate it.
Forgive me but I am not familiar with Robot. Would you please guide me through the steps to run the corrections?  I can not seem to find where this is located.
Thank you
Message 4 of 12
Message 5 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Have you managed to correct your model with the option @Anonymous (thank you) pointed you at?
Artur Kosakowski
Message 6 of 12
no it did not seem to work
Message 7 of 12
Thank you for you response. I followed the correction procedure and it did
not change the message. The calculation will not run. It seems all the
columns and walls are not assigned to a story. I have attached the file.
[image: Inline image 1]
Message 8 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach your model so that we could try to help?
Artur Kosakowski
Message 9 of 12
The file is attached. Thanks
Message 10 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It seems like you missed it.
Artur Kosakowski
Message 11 of 12
I apologize, the file should be attached now.
Thank you for your help
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to define smaller vertical panels among the levels of the stories instead of a single ones through the entire structure height.
Artur Kosakowski
