discard density in robot structural analysis
yahyasyd190MQUXY
Message 1 of 11
yahyasyd190MQUXY
hi
what is the deference btween these two disgard density in robot
 how should i use them if i include building mass in conversion would i have to check both or what is the right process
Replies (10)
Message 2 of 11
Simau
Hi @yahyasyd190MQUXY
If you have a load case with only SW you may let this box unchecked  then Robot will automatically convert SW to mass.
If you have SW mixed with other dead loads then you must tick the box and convert to mass these dead loads by yourself
M. Agayr
Message 3 of 11
yahyasyd190MQUXY
thanks but why it is exited now in two palces not like past versions
waht is the deference btween these two boxes?
in past was existing in the model form not in the static one
but now both
so how it was work in the past and what is the deference now
sorry for long speash
Message 4 of 11
Simau
The 2 pictures are completly independant.
The 1st one is about an equivalente force method which doesn't need to run a modal calculation first, so Robot ask you if you want or not to disregard the density.
The 2nd one is about a modal calculation which is followed by a seismic calculation.
M. Agayr
Message 5 of 11
yahyasyd190MQUXY
But in a version like 2019 robot it wasn't excited so what is the new property now?
Does it mean they were calculating automatically disregard or what?
Message 6 of 11
Simau
Sorry, previous versions are no longer installed here.
Could you make a screenshot showing this particularity
M. Agayr
Message 7 of 11
yahyasyd190MQUXY
it is the same window like this but without the disgarded bax
Message 8 of 11
Simau
I have no explanation
M. Agayr
Message 9 of 11
yahyasyd190MQUXY
But last question
Does the equivalent method take the mass from the conversion?
Message 10 of 11
Simau
@yahyasyd190MQUXY
Not automaticly
You must convert load cases acting in seismic case by your self. Except Selfweight if you let "Disregard density" box unchecked.
M. Agayr
Message 11 of 11
yahyasyd190MQUXY
Ok got it thanks
