Different Structure Reaction (Table and On display)
Why is there a difference between on display reactions and on table? on Table it has two kinds of Reactions. One is the "sum of value" which is same as on display and the other is "sum of reaction" which has almost 2.5x the reaction of the latter?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The prior is the sum of values from the currently displayed (selected) reactions. My assumption is that you have more supports than only the one in node 5 you filtered the display of the table to.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
