Difference between Foundation Elasticity and Elastic Support
Hello, I would like to ask what is the difference between "Foundation Elasticity" in Thickness setting and "Elastic Support" in support setting.
Also, I have another question. I previously applied both "Foundation Elasticity" and "Elastic Support" at my model. I found that the result values, like shear and moment become smaller after I delete the elastic support. I am quite confused why all design value become smaller when I delete the elastic support.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Check https://forums.autodesk.com/t5/robot-structural-analysis-forum/the-difference-between-planar-spring-support-and-elastic/m-p/7265477#M56046
If you use both they 'will add up" so your KZ will be 2* KZ instead.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
