unable to mesh with 1.0 element size
I am encountering a meshing issue. The model was able to mesh using 1.0m element size, however, after I added 6 short beams to connect a column to the shear wall, the model always stuck midway through the meshing using the same 1.0m element size.
Any help is greatly appreciated.
Regards
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to switch off the use of the regular mesh. If this doesn't work zip and attach your model.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi Mr Artur,
This is a project under my company, I am not sure if I can share it publicly online.
is there a way that I can send you the model privately?
Regards.
Pawel.Pulak
Autodesk Support
Autodesk Support
Some info for other forum users:
It was solved outside of the forum.
Model contained more than 2000 panels with unfrozen FE meshes.
It was necessary to run consecutively local mesh generation of cores and then slabs to obtain frozen FE meshes.
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
