Different manual combination table
Konrad.O
Autodesk Support Autodesk Support
Message 65 of 65
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Different manual combination table" topic:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/editing-load-cases-in-excel-api/m-p/8...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (64)
Message 40 of 65
Yes, I can see the problem now. When I'm using load combinations as basic load cases as well as having 27+ basic load cases, the factors from load combinations get written to the same columns as the last basic load cases.
Maybe I'm asking for too much, but do you know any way to make the xls file adaptive to the number of basic load cases imported?
Message 41 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
This macro works for combinations made of simple cases only.
For example comb 1200 contains comb 1000 + simple case
Rafal Gaweda
Message 42 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Finally I got your point.
Macro with no limits for simple cases and combinations (also embedded) attached.
Rafal Gaweda
Message 43 of 65
Fantastic! This is so useful.
Thank you
Message 44 of 65
mgaafar
Thanks, Rafal for your effort, I find this sheet very important and helpful.
If I may suggest also to make the sheet read Static-Seismic load cases in case a Seismic load case is created. it happened that I had one in a model and it didn't catch it in the import/export generation.
Message 45 of 65
danielroure2267
Hello
It's a good macro, do you know if there is a statement to block redisplay in RSA to accelerate the transfer?
Kind regards
Message 46 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @danielroure2267
Near the beginning of code add
RobApp.Interactive = 0
at the end
RobApp.Interactive = 1
Rafal Gaweda
Message 47 of 65
danielroure2267
Thank you
Message 48 of 65
danielroure2267
Hello
do you think it is possible to accelerate again?
the insert of a combination is done in 1 second; I have 80000
I found the link below but I do not know how to introduce it
is it necessary to limit the cache (ApplyCache) to a number of combinations?
is what BeginMultiOperation, (IRobotCombServer?) can be used
https://knowledge.autodesk.com/fr/support/robot-structural-analysis-products/troubleshooting/caas/sf...
thanks
Message 49 of 65
rokas_varanauskas
This appears to have no effect on time it takes to transfer combinations from Excel to RSA. In one project we have just under 2000 combinations which is taking more than 60min to get transferred. It's a lot of time.
Any improvements would be greatly appreciated.
Rokas
Message 50 of 65
ALEXTHAINESE
Adding label for load cases , is it poosible from excel to RSA using API?
Message 51 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ALEXTHAINESE
I am afraid it is not implemented in API.
Rafal Gaweda
Message 52 of 65
1234eddie
I don't know if it's still relevant.
But in this topic you will find a solution, thanks to rafal.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-load-case-labels-dynamo-api-pyt...
Message 53 of 65
JPNR87
does API "RMI_loadcomb_nested_with_subnatures" cooperate with RSA 2021. Im having a problem.
Thanks for answers!
Message 54 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @JPNR87
Yes it does.
What is the problem?
Rafal Gaweda
Message 55 of 65
JPNR87
Message 56 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 57 of 65
bos3UYUJ
Hi @Rafal.Gaweda,
In response to your video showing you copying loads from an excel spreadsheet to the "Table edition" tab in RSA, is it possible to automate this step with a macro. At the moment I have to copy and paste the table from Excel to RSA (like you show in your video) and I would like to remove this manual process.
Many thanks
Message 58 of 65
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @bos3UYUJ
I am afraid it is not possible.
Rafal Gaweda
Message 59 of 65
bos3UYUJ
No problem. Thank you for your quick reply.
Best wishes
