Design beam and support slab in his bottom
luismrf
Message 1 of 15
luismrf
i´m designing a beam and i want to support in is bottom a slab ( not on the top), how can i do it in the RSA?
thanks,
luis
Accepted solutions (4)
Replies (14)
Message 2 of 15
Simau
@luismrf
Before meshing, create intermediate nodes in the beam and on the side to be supported of the slab then join them with rigid links.
You may also use "offset"
M. Agayr
Message 3 of 15
luismrf
hi @Simau ,
i used the offset, but the results are the same or different using it?
How do you use the regid links?
regards,
Luis
Message 4 of 15
Simau
@luismrf
I don't understand your problem
The results are the same than what ?
Could you show results in both configurations
M. Agayr
Message 5 of 15
luismrf
Hi @Simau,
if i use the offset and place the slab in the bottom of the beam i get the same results if i didn´t used the offset?
The offset only changes the model graphically, the results are the same, no?
What i wanted to simulate correctly was to support the slab at the bottoom of the beam ,
regards,
Luis
Message 6 of 15
Simau
@luismrf
Here is a test model showing the differences with and without offset
M. Agayr
Message 7 of 15
luismrf
Thank you @Simau ,
i have one more question please, how can i make sure that the longitudinal beams get all the load sent from the slab ?!
Thank you,
Luis
Message 8 of 15
Simau
@luismrf
You need to create a new thickness with orthotropic material, for example this one in the screenshot
Model attached
M. Agayr
Message 9 of 15
luismrf
Thanks @Simau,
this was what i was trying to do, placing a linear release along the tranversal beams, but that didn´t worked.. why?
Message 10 of 15
Simau
@luismrf
If you have an isotropic slab, the load distribution on the support beams will be done according to the stiffness of these beams. It has nothing to do with the linear releases of the slab.
However if you create an orthotropic slab in the model, it must be orthotropic in reality
Take a look at this thread
https://forums.autodesk.com/t5/robot-structural-analysis-forum/moments-in-one-way-slabs/m-p/11975049
M. Agayr
Message 11 of 15
luismrf
@Simau i have a situation similar to this above but i don´t have a tickness i only have a cladding because i want to simulate a very light canopy, how can i send load only to the longitudinal beams?!
thanks Luis.
Message 12 of 15
Simau
@luismrf
You may use one way cladding which will send loads according to its local axis=
M. Agayr
Message 13 of 15
luismrf
thank you @Simau
and if i already have a cladding is it possible to edit oit to one way, or do i have to delete the one that i have and draw a new one?
Message 14 of 15
luismrf
Thank you simau,
i think i just fixed the problem, in Cladinngs, i just applyed to the one way y and it worked!
Message 15 of 15
Simau
You may also change it in object inspector
M. Agayr
